air pump removal 01 c5
Old 02-17-2012, 11:44 PM
mastercoryd's Avatar
Default air pump removal 01 c5
Hey guys, I'm used to f body world.. but I switched to a 2001 c5. I bought LG super pros race style (but they still come with AIR tubes/flange. As far as I know, no y bodies have egr. So before I install headers I'm going to have the air tubes/bracket cut off n welded. My question is, where is the airpump located? I'm assuming it.s four bolts and I just have to unplug it from the harnness. Also, my second question: is there a plug that they make so I can plug the tube that goes into my airbride/cai?
Thanks a lot guys
Old 02-18-2012, 11:56 AM
baxsom's Avatar
Hi,
If it is in the same place as my 00 C5 then it is in the front left just inside the bumper by the fog lights. You will need to have the code for a malfunctioning AIR tuned out of your computer. For the hole in the air filter I just filled in the plug that connects the rubber hose to the bridge and left it there.
Old 02-19-2012, 03:10 AM
Sounds good, I'll be tuning all codes out via efi live.. thanks
Quick Reply: air pump removal 01 c5
