WS6 Next Upgrade advice
Old 02-25-2012, 11:29 PM
Tubba's Avatar
Default WS6 Next Upgrade advice
I live in California and im Looking for advice to point me in the right direction on what to buy and install next on my 01 trans but still be able to pass smog emmisions, I'm looking for the best, so far:
Slp loudmouth exhaust
stainless airlid with k&n filter
vogtland springs
New Continental extreme contact tires
Old 02-26-2012, 04:44 AM
CHADsterss's Avatar
Long tubes with TSP catted ORY
Old 02-26-2012, 06:36 AM
gs462's Avatar
I concur and maybe a tune for CA. emissions
Old 02-26-2012, 10:36 AM
Tubba's Avatar
That's why I'm here, because my "friends" ante now in "county" so I'm looking for the most output while still passing emissions
Old 02-26-2012, 10:38 AM
cookba's Avatar
ya unless you have friends longtubes wont pass. there are cam's that have been tuned and can pass smog, talk to Pat G to get a spec'd cam. otherwise, start the suspension upgrades so you can actually use the power you currently have instead of spinning them away with those tires.
Old 02-26-2012, 10:44 AM
99french's Avatar
i would go for the nitto nt05 over the extreme contact. i had no problems with nt05 in washington state by seattle with rain.upgrade from the rear of the car to the front. call strano for the springs they are worth it.
Old 02-26-2012, 10:49 AM
01transampower's Avatar
224R cam from Texas Speed will give you a nice power increase and you should be able to get it to pass emissions relatively easy.
Old 02-26-2012, 11:17 AM
Tubba's Avatar
i was hoping someone would say cam lol tho is the cam guarenteed pass CA emissions or is it a maybe? I want the best and most aggressive but still be legit, i know i can't go TREX style but whats the closest. The reason is because the pigs been trying to catch me riding dirty, but I got beat by a Evo last week, can't let that **** happen again, what about injectors? Ignition **** even spray? How dangerous is a dry shot into the airlid?
Old 02-26-2012, 12:37 PM
omarrakeen's Avatar
budget? if its auto you can always do a converter since you cant do exhaust...a baby cam will pass smog too...along with gears...
Old 02-26-2012, 12:49 PM
There is so many ways to get a car to pass emissions with something "illegal" such as a big cam. But the 224r should pass easy. It won't give you a big gain like the Trex cam but probably another 35 rwhp with a good tune. Get it with a tall enough lsa and no one will ever know its there.
Old 02-26-2012, 05:51 PM
libertyforall1776's Avatar
Upgrade to a better State.
Old 02-26-2012, 10:06 PM
Tubba's Avatar
lmfao
Old 02-27-2012, 01:11 AM
99Bluz28's Avatar
224/224 114lsa is the unwritten size/overlap limit(-4*) for California, you can go with a different duration on the lobes but you need to keep the overlap to -4* or more(-6*, -8*, etc..). I'd also have your factory heads ported and milled or get a set of AFR 205s or 210s(has CARB EO#).
Old 02-27-2012, 01:18 AM
need2speed94's Avatar
224R cam and 243 heads for next budget mods
Old 02-27-2012, 08:48 AM
Tubba's Avatar
Thanks for the clarification 99bluz28
@need2speed. Will 243 heads affect emissions?
Old 02-27-2012, 07:29 PM
Nope! They'll just extract a few more ponies I'd only worry about a cam and headers effecting emissions, but as others have stated... the 224R cam is perfectly legal for emissions. Sounds pretty good even on a 114 LSA. Good luck with your car!
Old 02-27-2012, 10:55 PM
Tubba's Avatar
Thanks for the info bro!
Old 02-28-2012, 12:02 AM
ZTwentyAteU's Avatar
noone said it yet?
nitrous!
Old 02-28-2012, 12:47 AM
Tubba's Avatar
But whats the damage Im looking at with a basically stock ls1 and a dry shot into my airlid????
Old 03-02-2012, 12:45 AM
damage? like $ or real damage?
a 100 shot and someone that halfway knows how to use it wont hurt a thing. I've slapped a 100 dry shot hidden on a stock 98z28 before just to outrun someone. Not the right way, but it can be done
you can find used kits and parts and spend like $250 on a wet kit all the time if you stay on CL. Dry kits even cheaper.
