Which 102mm Throttle Body?
Old 03-01-2012, 07:29 PM
CMKworm's Avatar
Question Which 102mm Throttle Body?
I have heard the FAST's have issues with the blades sticking and they are the most expensive. I guess I am between the PTM and Nick Williams. Any thoughts or what you are running? Thanks, and sorry if this has been covered before.
Old 03-02-2012, 09:01 AM
firemech21's Avatar
Im running a NW 92mm and love it, I would assume that their 102 would be just as good. I have also called them and they have great customer service. I needed a new blade so when we talked last friday they got it sent out and it was in the mail lastnight.
Old 03-02-2012, 10:38 AM
Undertow74's Avatar
blades sticking is an old issue they have since fixed that. I have both a fast and a nick williams. both great TB's, the Fast just looks prettier. one of them is going to be for sale soon just dont know wich one. I dont need 2!
Old 03-02-2012, 11:50 AM
SweetS10V8's Avatar
Like said FAST has long since fixed their sticking issue. The NW throttle bodies werent designed to fit the 102mm from what ive seen. most people have a leak at the bottom of the TB because its too small of a diameter.
The FAST comes with a built in convelute that makes a big difference when trying to tune. Not only does it fit because they were designed together, but it has the convelute thats very helpful when running a 102mm TB that no one else does.
The following users liked this post:
91RSCamaroSteve (10-09-2023)
Old 03-02-2012, 12:14 PM
1989GTA's Avatar
While we are on the subject does anyone have the CFM ratings of the 102mm throttle body?
Old 03-02-2012, 12:44 PM
SweetS10V8's Avatar
More than youll ever need!!!!! Its actually irrelivant to 99% of people, other than pure curiosity. I know a guy who runs his twin turbo 632ci on a single FAST 102mm.
Old 03-02-2012, 02:49 PM
1989GTA's Avatar
"More than youll ever need!!!!!"
Maybe so but I am just trying to compare it to a 1300cfm monoblade that I have.
Old 03-04-2012, 11:02 AM
Turbosixx's Avatar
I have a FAST 102mm on my truck and the idle quality is less than acceptable. It hunts for idles if the blade is closed too fast. It seems like the IAC is too small to control the idle. Are there any cars/trucks out there with the FAST 102mm that have good idle characteristics? Is the Nick Williams a better throttle body? Oh, I have an LSXRT intake if that helps any.
Old 03-04-2012, 05:11 PM
2QuikTA's Avatar
Would that be a tuning issue?
Old 03-04-2012, 05:17 PM
Turd Gen Guy
1nasty86's Avatar
i had a nw 102 and it worked perfectly.. but i stepped back down to a fast 92mm and it works just as good...
Old 03-04-2012, 06:53 PM
Turbosixx's Avatar
Curiosity got the best of me. Started digging around and found a vacuum leak. Fixed it and it seems to be better.
My main concern was if the fast 102 can be tuned for good drivability. If so then I'll stick with it.
Old 03-04-2012, 07:21 PM
2QuikTA's Avatar
Good find on the vac leak! The tune as with every tune is going to rest in the ability of the tuner.
Old 03-05-2012, 02:58 AM
hdtp ws6 formula's Avatar
I just swapped to a 102 setup with a NW throttle body. I started it for the first time yesterday, and it has no problems with idling or driveability. I was a little concerned how it was going to be after reading all the threads talking about tuning and driveabity, but it works great. I do my own tuning, and had no problems getting the car tuned with the new setup. I've had a NW 90, NW 92, and now a NW 102, and they've all worked great.
Could you send me their phone number?
Old 03-05-2012, 08:25 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We sell a lot of the PTM & have great luck with them. Not to mention they're a little bit less $$ than some of the others. With thousands of them sold you know your getting a good product!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 04-03-2015, 09:32 PM
daniel28391's Avatar
Yes Fast throttle bodies still have this problem as of 2015, go with NW.. Fast 102 TB's suck
Old 04-03-2015, 09:37 PM
redbird555's Avatar
you realize you're bumping a 3 year old thread correct?
Old 11-05-2016, 09:53 AM
BrntWS6's Avatar
Im gonna bump it again. Been to my tuner several time to fix the idle hunt problem. No problem at all on a cold start, i could drive it all day and be fine. As soon as i turn the car off and on it has the idle hunt problem. Sometimes it will correct itself while driving. Tuner seems to think its mechanical, dont know squat about tuning so i have to take his word for it. Im going to replace the IAC sensor and if that doesnt work try a NW.
My FAST 92 is an older TB though but apparently they are still the same. These big TBs are a PIA to deal with.
Old 11-05-2016, 10:53 AM
BBWS6's Avatar
I have a Nick Williams 102 and have not had any issues.
Old 11-10-2016, 03:11 PM
BrntWS6's Avatar
Replaced the IAC with a new GM unit and seems to helped some but definitely did not completely solve my problem. Ordered a new NW in the anodized black...we will see. I will sell the FAST to recoup some of the cost.
Old 11-10-2016, 03:22 PM
Rise of the Phoenix's Avatar
Go with a WARR Performance 102mm TB. I've been hearing nothing but good things about their TB's, and they have outstanding customer service.
Quick Reply: Which 102mm Throttle Body?
