Victor Jr. intake manifold cracked!
May try consulting Edelbrock tech about it, since that shouldn,t happed. As far as repair goes, it could be tig welded. Crack must be v-grooved & area perfectly cleaned.Tig weld must be hot enough to properly take & not fail, which can be assisted by a mix of helium with the argon gas.
The engine was a completely stock 5.3. It looks like the casting was actually milled paper thin on the opposite side where the gasket groove is at. I have always used edelbrock stuff because of the high quality but this intake manifold has me wondering...
I have had the intake for at least 6 years so i know that Edelbrock is going to say screw me about any kind of warranty. I will just weld it. Probably wouldn't be an issue N/A but it's a turbo truck.
