longtube headers installed rubbing issues
Old 03-04-2012, 08:14 PM
Wayfastwhiteyaz's Avatar
Thumbs up longtube headers installed rubbing issues
just installed my stainless long tube headers and the driver side header is rubbing on a metal rod on the K-member it goes from back where the A-arm bushings are located to the front of the k-member it is held in place by two bolts does this piece matter as far as being support on the K-member or can i just remove it?
Old 03-05-2012, 06:28 PM
Grudge Night's Avatar
what type of long tube headers are you using ?
Old 03-05-2012, 08:49 PM
thier ebay longtube headers
Old 03-06-2012, 07:48 PM
UMD_Jesse's Avatar
Location: Fairfax County, VA (You know you're here when you see the bad roads)
can you take a pic?
Old 03-08-2012, 10:34 PM
http://sphotos.xx.fbcdn.net/hphotos-...35998432_n.jpg
Old 03-08-2012, 10:37 PM
ANTICOP RAM AIR's Avatar
mark where its hitting, take it off put it in a vice and bend it slightly, then open the holes a bit.... youll be fine... You could also take it off but if it were me, id try to make it fit..
Old 03-09-2012, 12:53 AM
BennyB's Avatar
I would just remove it. I don't think my car even has that?!
Old 03-09-2012, 01:19 AM
Cjm1991's Avatar
You would only need to bend it about half an inch, would take like 3 minutes. I'd leave it there if you can find a way around it just to be safe
Old 03-09-2012, 05:20 AM
omarrakeen's Avatar
lol same thought here..pretty sure mine doesnt have it too..this should be an easy fix.
Old 03-09-2012, 08:20 AM
99'CajunFirehawk157's Avatar
TSP for the win, none of that bullshit! No cutting, no dropping the oil filter, doing mine today.
Old 03-09-2012, 10:56 AM
ls1fan00's Avatar
haha i just installed ebays last saturday. fit like a glove. getting custom duals installed today. didnt even have to widen any bolt holes. i dont have that bracket either i would just remove it
Old 03-09-2012, 10:57 AM
babbage1109's Avatar
Maybe your motor mounts are shot.
Old 03-09-2012, 12:12 PM
The Scammer Hammer
dr_whigham's Avatar
Better late than never, Cajun. LOL
Old 03-09-2012, 05:59 PM
orangebird01's Avatar
Mine has that bar, maybe it's a vert only thing. My ebay headers also hit it, I put a 1/4" washer on the front side and bent the bar just enough to clear.
Old 03-10-2012, 02:14 AM
Yeah I think I'm just going to remove thanks for the help and I do think it's a vert thing.
Old 03-10-2012, 02:39 AM
CamaroZ28_LS1's Avatar
Originally Posted by Wayfastwhiteyaz
you having a vert, you have all weird kind of little stabilizer bars and **** on your K-Member. Prob just bend it or take it off really. I have OBX headers as well and the steering shaft hitting on the pipe was my issue.
Old 03-10-2012, 08:49 AM
I have those four braces, the are 2 in front, 2 in back...YES, I have a vert but mine didnt hit my headers....but to make it easier I unbolted mine during install.
Old 03-14-2012, 10:57 PM
Exclamation
Well I fixed the problem with the stabilizer bar and I'm still rubbing the four primary tubes coming down in between the k-member on the driver side are still rubbing looks like i could cut the k-member so they could clear but should I just try something else instead of hacking away at it? It's a let down on all the hard work it took to get them in there and now I have problems:/
Old 03-14-2012, 11:47 PM
scj
scj's Avatar
Prime example. You get what you pay for.
Old 03-15-2012, 01:52 AM
omarrakeen's Avatar
this is common with ebay headers...most of people with them have the same issue. how bad does it touch? you could try and massage the K member..
Quick Reply: longtube headers installed rubbing issues
