rebuild a ls1 or go lq9??? suggestions please!
so i spun a rod bearing a while back in my ls1 and i was just wanting some input on what to do. i would like to get my car back on the road asap and cash is kinda tight so what would be best rebuilding the ls or picking up a lq9 and doing the swap. could i expect more hp out of the lq9 if i went that route? there isnt to many people in my area thatup to date with the ls engines so any input would be much appreciated.
lol, i wish it was that easy. ive done got the engine and tranny out, cranks kinda scared up, im for sure going to have to have it turned to smooth it back out. thats why i was woundering if i should pay out the but for the machine shop and new gaskets, bearings etc.. or just buy a good lq9, swap my cam into it, hoist it back in and run the **** out of it.
it has somewhere around 65k on it. all seems to be in good shape though, ive rebuilt it once because i broke a piece of the piston between the compression rings somehow so i put everything fresh back in while it was apart. but turning the crank is more than likely the route ill go im just kind of skeptical because the local machine shop has never really had any experience with an ls. any advice on what the best bearings are to use and also is arp head studs and main studs worth investing in? overall i just want to build a good daily driver but one that will take as much abuse as possible.lol
a nice build and asap might not work together...even if you are on budget id still do it slowly and take all my time. you really dont want to drop the engine twice or re install a major part twice, which ever your choice is. to answer your question; it really comes down to the money. stock ls1 for stock lq9 isnt really worth it specially on a tight budget. you can simply rebuild yours with a cam upgrade and thats it. good luck!
