Rattling Cats???
Old 03-07-2012, 02:39 PM
Blownbayou's Avatar
Default Rattling Cats???
Think I have the rattle cat....... Rattles only when sitting at a stand still during idle. It comes and goes.... Example: Rattle Rattle Rattle................Rattle Rattle Rattle....... etc. Can hear it really well when next to a building or wall of some sort.
I thought it might be the heat shield around the cats, but they seem attached securely. Does this sound like a busted up cat????
Thanks
Old 03-07-2012, 03:33 PM
94Z28-MSTGKLR's Avatar
Sounds like it. My car was doing the same thing until peices of the cat started coming out of the pipe. Of course I had a sweet thunder dumped off the factory y pipe so it didnt have far to go. Took off the pipes to install the headers and my cats just dumped all over the garage floor.
Old 03-07-2012, 03:34 PM
joecar's Avatar
Is this on your F-body..?
On mine it was the i-pipe ID had expanded allowing the y-pipe to fit loose...
I fixed by expanding the y-pipe (using a pipe expander) so it fit snug in the i-pipe.
You might want to first check if this is it or not.
Old 03-07-2012, 06:01 PM
Blownbayou's Avatar
thanks for the replies.... F-bod for sure. Going to tap on the cats with a rubber hammer to see if I hear some loose chunks. If not.... going to check I pipe.
Old 03-07-2012, 08:25 PM
Moderator
jimmyblue's Avatar
Look on the bright side - now gutting ought to be a piece
of cake.
Old 03-07-2012, 08:42 PM
joecar's Avatar
Yes, piece of cake, if he doesn't need the cats for emissions testing.
Old 03-07-2012, 08:55 PM
blue95's Avatar
My '95 had the same symptoms...TWICE. The first time it started off as a rattle, then got worse and worse. One day, I was accelerating onto the interstate and noticed a definite loss in power. I stayed in the gas and a few seconds later had a large black puff of smoke exit the exhaust pipe. Turns out the guts had come loose and became unaligned with the exhaust pipe creating mass amounts of back pressure. So, I replaced the cat with with an aftermarket one.
2 years later, same symptoms...rattle rattle rattle.....rattle rattle rattle... I pulled the pipe, grabbed a loooong prybar and gutted it. Since it was a '95, it passed the visual inspection because it looked like it had a cat. Problem solved.
Old 03-08-2012, 01:50 PM
Blownbayou's Avatar
just worried about raspy sound on the magnaflow.......... Guess I can gut and if I do not like it, go with highflows
Old 03-08-2012, 02:05 PM
Nick V.'s Avatar
huh....i wonder if this is my rattling/marble sound.....
Quick Reply: Rattling Cats???
