Copper in oil but no engine noise.
Old 03-08-2012, 09:48 AM
maxgee's Avatar
Default Copper in oil but no engine noise.
Your thoughts if copper in oil but no engine noise.
If it were rod bearings I think I would hear noise.
Maybe crank to block bearings?
Old 03-08-2012, 10:19 AM
jmm98LS1's Avatar
Copper is likely bearing material, could be from mains/rods/thrust or cam (less likely). You wouldn't necessarily have noises with worn bearings. Only way to know is tear it down.
Old 03-08-2012, 10:56 AM
gMAG's Avatar
The crank, rod, main bearings are plated with silver colored material....probably tin and others.
The cam bearings (at least the ones in my car) are brass/copper colored.
Before you tear things up, you can remove the front cover, leave the heads on, and pull the cam out.
You should be able to shine a flashlight in the cam tunnel & inspect.
If a cam bearing is worn, THEN the engine will have to be pulled to replace the bearing(s).
Just wanted to add...the crank counterweights have a color which might fit into this category. If your crank thrust bearing was REALLY worn, a counterweight might be rubbing against the block. I doubt this, because then you'd have engine block iron or aluminum in the oil, as well.
Old 03-08-2012, 04:33 PM
gMAG's Avatar
Do you know what your oil pressure is...cold & hot?
Old 03-10-2012, 07:06 PM
67RSCamaroVette's Avatar
I'm gonna go with what Gmag said.. worn cam bearings. Almost every car I do a cam swap on, has worn cam bearings.. nature of the beast, I think.. The front one is nearly always worn thru the babbit from the chain tension. Just keep an eye on your oil pressure.
Old 03-10-2012, 07:29 PM
Darkman's Avatar
Other parts that can contribute copper, or copper color, to oil include some valve guides and newly installed oil coolers.
