Hard starting problem
I have a 2002 camaro ss.For the past 10 years it has always started fast , after 1 or 2 turnovers.Over the past couple of months it will turn over 8 to 10 times--no start key off then try again ,after 5 or 6 more tunrovers it will start.Runs fine after it starts.What could be causing this? thanks
OK I can rent a fuel pressure tester. Should i turn the key on and test the pressure at the schrader valve? What readings are good and what readings tell me i have a problem?
