Stock internal N/A H.P. record?
Don't know about the RWHP record, however, there is a sticky in the drag racing section that shows the quickest stock internal cars.
https://ls1tech.com/forums/drag-raci...1-74-bump.html
I meant that if you have full bolt ons and get readings of over 350 something is up with the dyno more than likely.
The only dyno comparisons that are valid/accurate are ones done on the *same* dyno. A car that hits 350 RWHP on one dyno might show as 330 RWHP on a different dyno.
It's like trying to compare d*** sizes when everyone's ruler has different inch measurements marked on it.
