Which heads for 383?
Old 03-25-2012, 03:17 PM
dlross's Avatar
Default Which heads for 383?
Looking for new heads for my ls1 383 stroker. just need some input on what would be the best heads.
Old 03-25-2012, 08:17 PM
dlross's Avatar
Bump........
Old 03-26-2012, 08:00 AM
ScottyBG's Avatar
You have no responses because you have asked a totally open ended question. If you would like a response, rephrase you question to somthing like this.
"I would like some opinions on the best choice for a head under $1500 (or whatever your budget is)for use on my 383 stroker. I would like to be able to use the stock rockers. The intended use is a weekend cruiser with an occasional trip to the drag strip. Drivability and throttle response is more important than being a dyno queen. The car is an A4 with a 3600 converter."
Some details about the cam you intend to run and the pistons, ie flat top, with or without valve reliefs, etc. will also help. If you have decided that you want a ported factory or an aftermarket head you could also help you further define it. I'm not trying to be disrespectful here, just help you get some meaningful info, and not crickets.
I have found how the question is worded, makes a huge diference in the quality of the responses.
Old 03-27-2012, 08:01 PM
dlross's Avatar
the spec are, 383 stroker, JE pistons, Eagel Rods, Eagel crank, , TexasGiant Cam 248/254 613/622 114 LSA, FAST 90 intake, 90mm UMI tb, Pacesetter long tubes no air or egr Pacesetter off road Y ,B&M 24k tranny cooler, MTI clear lid, svo 30lb red top injectors, upgraded walbro pump, Prothane motor mounts, 160 Hypertech stat. I'll be going with the yank pt4000 converter. I'd like to see nice numbers off the dyno but not to worried as long as e.t time are nice. Thanks for the help
Old 03-28-2012, 12:58 PM
BAD2000TA's Avatar
AFR 215 would be a good choice.
Old 03-28-2012, 01:01 PM
Rise of the Phoenix's Avatar
What's your budget? If money is no option, you can't beat the new MAST heads, or as set of AFR 215, TFS 215, PRC 215 or 227. Those are the "big name", "big horsepower", "big money" heads on the market.
Old 03-30-2012, 12:39 AM
dlross's Avatar
Well I talked to afr and the recommened me to go with there 230 heads. So I think thats the way ill be going.
Old 03-30-2012, 09:41 AM
Wish I had your coin. I could sure use a set of the AFR 210 heads. Can't go wrong with AFR, that's for sure.
Old 03-30-2012, 10:38 AM
Detoxx03's Avatar
When I had mine I was gonna put the Trick Flow 225's on it.
Old 03-30-2012, 08:11 PM
SOMbitch's Avatar
What happened to your car Detoxx??
Old 03-30-2012, 08:18 PM
Turd Gen Guy
1nasty86's Avatar
With your budget id get a set of trickflow 215's and have ls3 valves cut down.. Be a really nice head
Old 03-30-2012, 10:13 PM
garygnu's Avatar
also look at the PRC 227 heads.I feel you will need bigger injectors.
Old 03-31-2012, 01:27 AM
Detoxx03's Avatar
Totaled in August. I was rear ended.
Old 04-02-2012, 08:45 PM
dlross's Avatar
I def think im going afr 230s. Im looking for around the 500hp # and afr said with my cam that shouldnt be a prob.
Old 04-03-2012, 06:33 AM
sheikss's Avatar
A.I. 226cc 243's would be another option if afr money seems a little high. They perform a lot better than their price would indicate, especially if you can track down a used set of 243's.
Quick Reply: Which heads for 383?
