Please Quick Help TRAP DOOR METHOD
The cut, sides and rear, front side left intact.
Panel pulled back down. Two small strips of sheet metal riveted in-place to hold the panel flat and then sealed with foil tape for AC ducting. The sheet metal pieces swivel out of the way to let the panel come back up for quick access.
Thank Hilton for the idea, he did it.
The following users liked this post:
OhTwo (07-26-2023)
I used the exact diagram that people have quoted in this post and im gonna be honest itts a pain in the *** with those dimensions. If yyou want a lil more room to work with id go a little larger by a few inches on each side
I'll have to admit, I did have to bend one of the locking arms upward to to get the lock ring up through my trap door cut out since I tried to make mine as small as possible. So if anyone does one as small as mine you might want to consider cutting it about 1/4" lower at the bottom.
Buddy just came over and did mine for me and he cut 3 sides and peeled the panel back. During reassembly he drilled two holes just to the outside of the cut panel and we took 2 pieces of sheet metal and drilled holes in them. He then riveted the sheet metal to the body panel holes. The top riveted pieces will swivel over the panel to hold it down or swivel out of the way quickly to pull the panel up for access. We sealed it with silver foil tape to act as a vapor barrier. Quick and easy process that works very well.
