71k miles..... new wires???
Old 03-30-2012, 08:45 PM
Blownbayou's Avatar
Default 71k miles..... new wires???
toying with the idea of changing plugs and was wondering if wires are needed with this low of mileage.... I have a slight hitch during idle and had a bout of detonation at wot the other day. Plugs are easy to come by (ngk tr5s) but I am not buying that cheap a$$ omni garbage from oriellys. ''
Input please.... I will also be going bbk headers in about two months.... Should I just wait it out till then????
thanks
Old 03-30-2012, 09:00 PM
01transampower's Avatar
Get a set of msd wires. For 55 bucks you cant go wrong. Its plug and play all pre-cut as well as the 8 ohm's restant wires which is way better then the stocks stuff.
Old 03-30-2012, 09:23 PM
TransAmWS.6's Avatar
You might as well do the wires as well if you're doing the plugs, I'm at 73k here and my car needs plugs/wires pretty bad, mines are gapped at like .70 and they're supposed to be at .50 I believe. So, I'm sure it wouldn't hurt for you to get ahead of the game and replace them. I think GM claimed that they were supposed to last 100k miles but that sure doesn't seem true.
Old 03-30-2012, 09:36 PM
ULTIMATEORANGESS's Avatar
Smile
do they have cracks or are they separating at the boots?
if theyre OE or cheap wires id change them.
Old 03-31-2012, 07:16 AM
Blownbayou's Avatar
wires look good visually...... I can get ngk tr5s and msd wires from amazon for 71 dollars delivered. Just have to wait till next weekend
Thanks
