true duals with spohn tunnel mount t\a
so i have read endlessly on going to true duals, and i have been told that since i have the spohn tunnel mount t\a i cant run true duals. now i know you can custom make something that will fit. Has anyone been able to do this? want to ditch my y pipe very badly. and if anyone has, please lets see some pics!!
I dont have any pics of it but I had a local guy make me a 3" TD setup that fit with my UMI tunnel mount t/a on my old SS. It cost me about $1400 to have it done including the panhard relocation but it sounded and performed great.
I have the TSP TD with x pipe and my UMI long arm fits. It was mounted to the tranny now it is on a relocation mount. I have a drive shaft loop and a3.5" shaft its all real close on clearence but fits.
can you guys get any pics for me? i want to build it all myself. i just want pics to see exactly where the x pipe is placed i think that is the major issue with the tunnel mount arms.
this is a pic off of spohns site just to show what a y pipe setup is like. Now I should also mention I am running 3 pt SFCs as well. I feel like i am pretty much screwed and will have to run a y pipe
Well my pics aren't the greatest but UMIs torque arm was matched for TSPs TDs. It offered about 3/4-1" clearence over the stock TA. Which is alot when it comes to TDs.
http://pix.kg/p/450551666311%3A859502940/sct but if your doing it yourself, everything will be alittle different and you should be able to customize what you need and want.
It pretty much boils down to you can either run the pipes tight together coming out of the x-pipe and over the crossmember or swing them out really wide to go around the crossmember. The problem with going around is there isn't any room in the floorpan to tuck the pipes up, so the clearance will really suck.
The best thing for true duals is to run a full length torque arm and a torque arm relocation kit. This set up gives you the most clearance and room to work with. Check out link below to one of our builds that uses this set up with true duals:
2002 Camaro with UMI torque arm & true duals
10 series single chambers are one of the best, if not THE best performance muffler you can buy. Small, lightweight, inexpensive, and doesn't rob power. Loud and very aggressive without sounding like raw noise, it has a menacing tone to it - unlike a bullet muffler. Drone is only an issue if you dump them.
