starter is an over achiver need help!
Just went out to start my car and after it cranked over the starter stuck...so I turned it off and pulled the key...the starter was still going!!!!! All the way until I got pliers and pulled the ground off the batt. Wtf is going on? P.S tried it again same thing!!!! Wtf
[QUOTE=1stIDFO;16186111]Just went out to start my car and after it cranked over the starter stuck...so I turned it off and pulled the key...the starter was still going!!!!! All the way until I got pliers and pulled the ground off the batt. Wtf is going on? P.S tried it again same thing!!!! Wtf[/QUOTE
Mine did the same thing the other day. I tried smacking it with a hammer to get it unstuck but no luck so i just bought a new starter. Was going to pull old moe apart but haven't got around to it yet.
68bbchevelle did yours stay cranking after the key was out too? this starter is about 2 months old now, shitty if i gotta replace it...again ... I've had starters stick, but not stay cranking after the key was out
I would double check to make sure the trigger wire to the solenoid isnt touching the hot wire from the battery at the solenoid. That would trigger the starter immediately when the battery is connected so probably not it but its worth a shot
