Oil pressure AND temperature gauge sensors into a LS1 Oil Cooler Block Off Plate?
I want to install an oil tempature and oil pressure guages. I plan on threading the 'oil cooler block off plate' above the oil filter for oil pressure. I wanted to know if it would be possible to add an adapter that would allow two sensor fittings(pressure & temp) into one that would then thread into the plate. Would the oil pressure reading remain accurate and would these connections be reliable. I want to retain the factory dash oil pressure guage and sensor.
