bad o2 sensors cause low/rough idle?
So my check enginge light came on so i checked to see what threw the code and its the o2 sensors have gone bad. Could this cause a low and rough idle while stopped or under initial acceleration from a stop? Only happens within the first 20-30 minutes of driving then stops doing it and runs normal. Any ideas?
Could be a number of things. Are you getting any O2 codes or any codes at all? Could be a fuel pump on its way out, could be O2's failing, could be a MAF failing & so fourth.
I chased a stumbling problem for a couple weeks on mine. It would drive fine then mess up. I replaced O2's/plugs/wires/intake gaskets/MAF/fuel filter & finally after all that the pump started to whine so I tossed in a Racetronix pump. Car runs like a champ now especially with the other service items replaced, LOL.
