Do I have everything?
I picked up an ls6 intake last week and I've been prepping it off and on all week, previous owner had it green and did a fast black rattle can job. Got it primered just waiting for a good time to spray it Gloss Black. This is my first time painting really, besides calipers so I'm pretty proud of how it's turned out so far. Here's a pic
Got around to painting it gloss black today.
Here’s my checklist.
I’m doing ls6 intake with longtubes into a x pipe with flowmaster 10s dumped at the axle while also deleting the EGR/AIR. Not really planning on doing motor mounts but I’ll add them just in case. Going to have a local shop fab up a custom x for me
Tell me if I'm missing something:
Ls6 Intake
It was ported to fit an 85mm throttle body so I’ll have to get some gasket material and make one to fit my stock throttle body. I’ll also be reusing the Intake bolts unless told otherwise.
Ls1/6 Intake Gaskets and Pads
http://www.summitracing.com/parts/FEL-MS92438/
Ebay Headers
http://www.ebay.com/itm/CAMARO-FIREB...item231b95f159
Header Gaskets
http://www.summitracing.com/parts/NAL-12617944/
Header Bolts
http://www.ebay.com/itm/LS1-Header-B...item2c6318e8f6
o2 Extensions
http://www.ws6project.com/user_stor/...or-extensions/
2 Mufflers
http://www.ebay.com/itm/FLOWMASTER-S...item4cf2833623
2 Header Clamps
http://www.ebay.com/itm/Formed-Clamp...item483d7b90e4
Motor mounts
http://www.ws6project.com/user_stor/...-motor-mounts/
Oil Pressure sending unit
http://www.summitracing.com/parts/SMP-PS303/
^^^ Socket
http://www.amazon.com/Lisle-13150-Pr.../dp/B0002SR2V0
Plugs and Wires
http://www.ws6project.com/user_stor/...s-wires-combo/
That’s all I can think of at the moment…
Ls6 Intake
Ebay Headers
Header Gaskets
Header Bolts
o2 Extensions
2 Mufflers
2 Header Clamps
Motor mounts
^^^ Socket
Plugs and Wires
maybe i missed it on your post but..
you doing ls6 coolant cross over line/plug kit?
Are you going to get it tunned after removing AIR/EGR and adding the LS6 intake?
Im sure your intake will turn out good gloss black.. take your time
Yeah. I just recently seen on here about the ribs being removed. I'll give it a go. And about the tune, I do plan on getting it tuned afterwards, just not sure when. It's my daily driver
Very nice car btw, I love that color.
http://www.texas-speed.com/p-111-msd...lug-combo.aspx
Will these do?
Will these do?
I'd do motor mounts for sure, my eBay headers fit perfect btw, hope you have the same luck as me! Just to save you some money if you can pull your spark plug wires off without ripping them apart you can reuse them, same goes with your oil pressure sending unit.
