New 85mm MAf not working, any ideas?
ok i replaced to a fast 92 intake and TB. got a GM 85mm maf with pigtail, loaded the car to take to the dyno, got everything all hooked up and the maf was reading a 0. i tried wiggling wires and everything, GM is going to replace both maf and pigtail, but this happen to anybody else? could it be something else?
Moderator
Something isn't hooked up, most likely. Did you probe
the voltages on GND, out and power pins of the pigtail?
Check GND against BAT, since a good ground and an
open will both read ~ 0. Output should be just under 5V.
