3inch band clamp help
Old 04-22-2012, 10:48 AM
ds98formula's Avatar
Default 3inch band clamp help
I have a couple of 3 inch band clamp I just got. I need to use them for attaching my y to my headers. They have some black tar looking stuff with them. I am assuming I am supposed to smear the tar across there the two sides bolt together? I just want to make sure befor I do it. Thanks
Old 04-22-2012, 11:53 AM
Darkman's Avatar
It sounds like it is exhaust paste. If it is not it will just burn off.
Old 04-22-2012, 12:11 PM
chadroosa's Avatar
not sure about that, when i do exhausts on semis i use band clamps never used any tar stuff and they dont leak
Old 04-22-2012, 12:31 PM
The Scammer Hammer
dr_whigham's Avatar
Definitely weird.... my Accu-Seal / Torca / Torctite clamps never had anything like that.... Almost sounds rather like a repair clamp than a regular band clamp.
Old 04-22-2012, 02:37 PM
Thanks for the replys. It was a patch of the sealer right where the two ends meet in between the bolts. So I put it even on the joint and it worked perfectly.
