Misfire on drivers side?
Hello everyone,
I just installed longtubes on my car 2 weeks ago and got a ecm mail order tune from Frost. After installation, I put about 500 miles on my car with no problems. This weekend I was driving and the transmission started shaking like crazy and the engine had no power. Luckily I was close to my house so I went home immediately. The car drives great for the first 20 seconds after start up, but when I took a look at the spark plugs on the drivers side, they were all full of carbon. Any ideas? I already replaced the plugs, I dont want to do wires yet because I have a feeling it is an electronics problem. Help!
Thanks in advance,
Dave
Thanks in advance,
Dave
one quick easy way to find out is to unplug the FRONT o2 sensors. let the car warm up to the operating temp. go for a drive. if its fine then it is most likely your O2 sensors provided you dont have any other sensors that are bad. and dont worry its totally fine to drive without O2 sensors. black plugs from the longtubes are some how common due to a rich condition. good luck.
Ok I got a code, it is p0131. Just so everyone knows, I had the rear O2 sensors tuned out by Frost. Right now I am driving with no senor (hole is plugged) because it is the only way it will work. I have searched other threads and found that others have had similar problems, but this is only ONE code, not for both sides. Here is what I have found to be working correctly: correct fuel pressure, no vacuum leaks, no wires are burnt (that I can see), and the PCM is on tightly and making contact. I am only drawing 155 mV and should be higher
