BBK Headers - LS1TECH
BBK Headers
Thread Tools Search this Thread
Old 04-29-2012, 11:10 PM   #1
Sladester2's Avatar
Default BBK Headers
Do the lontube BBK headers, http://www.bbkperformance.com/produc...ch-y-pipe.html, work with EGR and if not what would I do? Just leave it unplugged and tune it out?
Sladester2 is offline   Reply With Quote
Old 04-30-2012, 01:55 AM   #2
flintwrench69's Avatar
Quote:
BBK only sells race headers for the Fbody so theres no EGR or AIR tubes. You would want to delete these items & tune them out with BBKs.
flintwrench69 is offline   Reply With Quote
Old 04-30-2012, 06:02 AM   #3
Leave them unplugged and only issue u will have is check engine light, won't hurt performance or motor at all, or pay for a tune and get those codes deleted plus 2nd o2s if u need to
sheaadams86 is offline   Reply With Quote
Old 04-30-2012, 11:41 AM   #4
nmbr5ml's Avatar
You will get a Check Engine light as a consequence of not tuning out the EGR/AIR systems; if that doesn't bug you then it's fine, but you can't just "unplug" those systems. You must remove them/pull the AIR fuse/plug the EGR inlet on the front of the intake manifold/plug the AIR inlet at the back of the intake manifold. You must do this to avoid a vacuum leak.
nmbr5ml is offline   Reply With Quote
Old 04-30-2012, 12:56 PM   #5
LS1Tech Sponsor
MikeFSKSpeed's Avatar
As stated they are made as Race Headers, no EGR/Air/Cats.
If you decide to go that route, PM me before buying. I have the Ceramic and Chrome ones in stock, discounts for LS1Tech members,!
MikeFSKSpeed is offline   Reply With Quote
Old 04-30-2012, 06:19 PM   #6
Sladester2's Avatar
What do I need to get rid of those systems? and how hard is it?
Old 04-30-2012, 06:32 PM   #7
98cobrakiller's Avatar
its easy just unplug and pull it out. i have bbk headers on my 98 trans am and my buddy has them on his 00 ss. took us 5 hours. thanks to a lift and a snap on tool box of goodies and alot of know how. its well worth the time
98cobrakiller is offline   Reply With Quote
Old 04-30-2012, 07:20 PM   #8
Easy, I have BBK as well..just take off the EGR and pull out the air pump..its all forward stuff really..
Then get a mail order tune so you can get the rrearO2,AIR, and EGR all deleted
DeLaRosa25 is offline   Reply With Quote
Old 04-30-2012, 08:47 PM   #9
Sladester2's Avatar
Thanks guys! Ya I plan on getting a tune from Frost afterwards!
Old 04-30-2012, 09:27 PM   #10
When you get the rear o2 sensors deleted go to your parts store get 2 18mm 1.75 drain plugs to go onto the o2 binges
Old 04-30-2012, 10:07 PM   #11
Sladester2's Avatar
Do these look like a good deal or a rip? http://stlouis.craigslist.org/pts/2984025196.html
Old 05-01-2012, 12:55 AM   #12
Quote:
The BBK ORY comes with the rear sensor plugs so I dont know why you would buy drain plugs. The thread size is actually 18mm X 1.50.
No, I dont recommend those. Not that great of a deal, just painted headers that will rust up very quick & you will need a Y pipe too.
Old 05-01-2012, 05:59 AM   #13
Nmbr5 what air inlet at the back of the intake manifold??? I didn't have one
Old 05-01-2012, 07:21 AM   #14
my bbks didnt come with plugs for the rear so when i deleted my rear o2 sensors i found something that worked drain plugs and yeah sorry 18mm 1.50 threads. i could of left the old o2 in there but it looked cleaner underneath with them gone and stainless drainplugs in there
Old 05-01-2012, 07:23 AM   #15
nmbr5ml's Avatar
You'll find 3 hoses from the AIR system that route around under the hood and lead back to a round thing on the rear (driver) side of the intake. If you can get back there, there is supposed to be 1 little nub you can cap off. Well, I got tired of slicing my arms up under the cowl, and got lazy, so I just got back there with some snips and cut those hoses off as short as I could and plugged all three to be safe. They're completely back out of sight so I didn't really sweat the details.
Also, there is no reason to extend and continue to use rear O2 sensors in an off-road Y-pipe, but if you're not saving those rear o2s, you can just clip the wires off and use them in the bungs. Otherwise, yes, you do need bolts or something to plug those bungs.
Old 06-09-2012, 10:24 AM   #16
Whitefish's Avatar
Is the BBK ORY ok? I noticed it was only 2.5-inches. I have a 3-inch borla cat-back & don't want to put the squeeze on my system by having the smaller ORY.
Whitefish is offline   Reply With Quote
Old 06-09-2012, 11:01 AM   #17
Latch's Avatar
Quote:
2 2.5" pipes flow better than a single 3".
Latch is offline   Reply With Quote
Old 06-10-2012, 12:03 AM   #18
99Bluz28's Avatar
Quote:
Two, 2.5" pipes flow slightly better than a single 3.5" pipe.
99Bluz28 is offline   Reply With Quote
Old 06-10-2012, 12:05 AM   #19
adamantium's Avatar
SICK LED's in your hood scoops bro!
adamantium is offline   Reply With Quote
Old 06-10-2012, 02:47 AM   #20
Sladester2's Avatar
Quote:
Thanks alot man
Related Topics
Thread Thread Starter Forum Replies Last Post
BBK Long tube headers MikeWS6 Generation III External Engine 23 02-19-2017 11:04 PM
BBK Performance Nicelysedate LS1TECH Sponsor Feedback 0 03-17-2015 10:58 AM
BBK Headers .boB Generation III External Engine 6 02-07-2014 04:01 PM
BBK 16905 Corvette C5 Stainless Steel Off-Road X-Pipe - NEW - $300 Shipped ThreeFiveSS Parts Classifieds 0 10-11-2012 10:46 PM
BBk Header any good? sean1997ws6 General LSX Automobile Discussion 10 09-26-2009 01:33 AM
Tags
98, air, bbk, block, camaro, delete, egr, header, headers, ls1, plug, plugs, ss, transam, tubes, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
