solid motor mounts - LS1TECH
solid motor mounts
Thread Tools Search this Thread
Old 05-02-2012, 08:34 AM   #1
Default solid motor mounts
Edit:
I am going to replace my poly motor mounts with solid motor mounts. I am looking at UMI and motovative. Has anyone had a problem with stress cracks or any other failure of the motovative mounts? If so, how much power were you making? If anyone has switched from motovative to UMI, was there a noticeable difference?
Update: Put in the UMIs and couldnt be happier with them.
Pseudonym is offline   Reply With Quote
Old 05-02-2012, 10:17 AM   #2
sjsingle1's Avatar
i would like to know too.......since this has never been asked ........j/k
sjsingle1 is offline   Reply With Quote
Old 05-02-2012, 10:30 AM   #3
Starkey's Avatar
I used the UNI solid mounts on an old El Camino I had for a little while. 350 solid roller engine. The mounts stayed well, didn't crack, and fitment wasn't a real issue, but the whole car shook (to be expected with solid mounts). I did have issues with the fenders getting a bit out of whack, probably because of the vibrations.
I haven't used solid mounts since, poly mounts seem to work well for medium builds.
Starkey is offline   Reply With Quote
Old 05-02-2012, 11:57 AM   #4
Quote:
Yeah, I know this question has been asked before. I will edit the original post to clarify.
I am expecting it to shake a bit, Im not concerned with that. I have polys now and I have had a strange issue with them. They melted, like this but worse.Melted Motor Mount???
Old 05-02-2012, 12:59 PM   #5
Starkey's Avatar
Interesting post on the melted poly mounts... I've never had a problem with them, even running headers.
Old 05-02-2012, 01:27 PM   #6
T3X_SS's Avatar
Never heard of melting motor mounts....., curious to see if anyone else has had a problem
T3X_SS is offline   Reply With Quote
Old 05-02-2012, 01:57 PM   #7
sjsingle1's Avatar
running poly here for over 2 yrs with TSP LTs......no melt
Old 05-03-2012, 06:09 AM   #8
Quote:
It was probably just me and the other guy from the thread I posted.
Anyone know of a failure of motovative mounts? Should I just spend a little extra and get the UMI mounts?
Old 05-03-2012, 07:27 AM   #9
sreve's Avatar
i do prefer the polys. I had Moroso solids on a 396 4sp. Chevelle the left mount thru bolt
hole would wallow out and make noise changed out the left side more than once.
sreve is offline   Reply With Quote
Old 05-03-2012, 08:36 AM   #10
LS1Tech Premium Sponsor
UMI Performance's Avatar
The solid mounts are going to work the same and there won't be any performance difference between the two. The main difference is weight, our mounts will weigh less and the solid aluminum constructions is the reason for the increased price.
I hope that helps,
Ryan
UMI Performance is offline   Reply With Quote
Old 05-03-2012, 08:39 AM   #11
babbage1109's Avatar
Midwest chassis has solid motor mounts also. Look into those
babbage1109 is offline   Reply With Quote
Old 05-03-2012, 08:50 AM   #12
BennyB's Avatar
I run umi solids. I hated the install (motor in car), but loved the results from them. Going from stock to solids I hardly even noticed them. I know you don't care about vibes I just don't get people that say they had so many vibes after solids so went to polys. I honestly think them peoPle have no experience running solid mounts. Just my 2 cents
BennyB is offline   Reply With Quote
Old 05-03-2012, 04:55 PM   #13
thegroup's Avatar
Be sure to run a poly trans mount then or stock rubber. I've heard horror stories about solid motor and solid trans
thegroup is offline   Reply With Quote
Old 05-03-2012, 05:22 PM   #14
93camaro_zzz's Avatar
Not to diss UMI, cause I think they are a great company, but I thought I remember some fitment issues with their solid mounts. Try doing a search on that.
93camaro_zzz is offline   Reply With Quote
Old 05-04-2012, 08:20 AM   #15
Quote:
I hope that helps,
Ryan
Thank you for the information. The price difference is not that drastic considering the difference in shipping costs.
Quote:
I saw those after I posted this. Thank you.
Quote:
I havent run solids yet, but it seems like people who had them in older cars have more problems with them. My dad had a set, similar in style to the motovative mounts, in his 68 camaro that cracked. Thats the reason I was asking about any known failures with them. Thanks for sharing your experience.
Quote:
Already have the poly trans mount installed. Thank you.
Quote:
I didnt see anything like that when I searched, but I will look again. Thanks.
Old 05-04-2012, 09:16 AM   #16
I have the motivative mounts and have no movement or any cracking. I've had them in for almost a year now
Old 05-04-2012, 11:06 AM   #17
deerslayinrednek's Avatar
I've had the Spohn Solids in for a month or so and love them. Plus they look better and are 9lb lighter
deerslayinrednek is offline   Reply With Quote
Old 05-04-2012, 11:38 AM   #18
Quote:
Originally Posted by deerslayinrednek View Post
I've had the Spohn Solids in for a month or so and love them. Plus the look better and are 9lb lighter
Dont they also raise the engine height by an inch? Unless they've change their design
Old 05-04-2012, 02:31 PM   #19
I am ordering the UMI mounts this weekend. Thanks everyone.
Old 05-04-2012, 02:53 PM   #20
4U2NV-SS's Avatar
Keep us posted on how they worked out for you!
4U2NV-SS is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Tax Time special: Motovative Solid Motor Mounts - 89.99 SHIPPED!!!! Motovative Sponsor Sales & Specials 33 04-26-2011 11:55 AM
Solid Motor Mounts...old idea with a whole new design! Motovative Generation III External Engine 43 03-29-2011 07:35 AM
Pro's & con's of solid engine mounts LS1-450 Generation III External Engine 22 03-23-2011 08:21 AM
Motovative Solid Motor Mount Install RedTtop6spd Generation III External Engine 11 01-28-2011 10:32 AM
Motovative Performance launches LS1 F-body Solid Motor Mounts Motovative New Products Showcase 0 12-15-2010 05:57 PM
Tags
350, 99, difference, installing, ls1, ls1tech, motor, mount, mounts, noticeable, problems, solid, trans, umi, widths
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
