5.3 brackets - LS1TECH
5.3 brackets
Thread Tools Search this Thread
Old 05-03-2012, 10:29 AM   #1
Default 5.3 brackets
i am doing a 5.3 swap in my 95 camaro and need to know if i need the truck brackets for the power steering and alt or can an ls1 brackets be used?any help would be great
darkfire71 is offline   Reply With Quote
Old 05-05-2012, 09:10 PM   #2
camaroboricua's Avatar
f body brackets are the preferred method but they are hard to find and expensive. I used the truck bracket but i cut off the alt top and kept the bottom part for PS pump. I moved the alt to the pass side in front of the head. I used a 98 f body water pump. the pulley is attached with four bolts so I went ahead and used spacers on it with longer bolts so that it will work with the truck accessories
camaroboricua is offline   Reply With Quote
Old 05-05-2012, 09:12 PM   #3
Quote:
What bracket did you use to mount the alt. ?
Nic Morales is offline   Reply With Quote
Old 05-06-2012, 11:46 PM   #4
I used my old third gen alt mounted to one of the tabs on the water pump. then I made two brackets to hold it in place.
Old 08-31-2012, 10:59 AM   #5
Im also in the process of doing a 5.3 swap. I'll be using a LS1 intake mani and i want to use a ls1 water pump also, am I going to be able to use all the other brackets and pulleys with an ls1 water pump?
Ricky702 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
5.3 alternator bracket cutlassreese Parts Wanted 1 01-12-2016 09:41 PM
Wtb coil pack bracket for 2007 5.3 fanta141 Parts Wanted 3 04-22-2013 11:29 AM
help with gto ls2 brackets s10pro Conversions & Hybrids 4 04-12-2013 10:03 AM
wtb ls1 coil pack/brackets/harness zayne0 Parts Wanted 3 10-29-2012 01:11 PM
coils brackets Mike Cordero Parts Wanted 5 10-03-2010 10:59 PM
Tags
53, 95, accessories, accessory, bracket, brackets, camaro, cutting, ls1, power, powersteering, pump, sbc, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
