Header install gone wrong!
Ok, so I bought a set of pacesetters here from a forum member... Got them and the Y for a great deal, they are brand new he just never put them on. First mistake I made was never asking if they were EGR, I wanted race style. They showed and I saw the EGR tubes but thought o well I can work with that. I went to install them yesterday, and realized my EGR tubes weren't going to line up correctly... I did research and these are 70-2253, which are for a 98-99 ls1, I need 70-2256 lol. Now I am sitting with my car stripped and basically no options. Ugh... I thought about taking them into a shop and having them chop off and weld up the holes but then they would be needed to get re coated.
If I were u I would just sell them and get ones that were made for ur year it's common mistakes I'm just not a fan of modify parts that u can get without the need in ur case they make the part u need with out modify it just my opinion I'm sure u can sell those headers and get ur money back
Yeah, I am the same way. I am going to just front for race version new from marylandspeed and get these sold asap. I just can't believe I was stupid enough to think a header install could go smooth... LOL it's always something...
unplug the blower behind the left side bumper cover, remove the blower and put in your scrap pile, remove the hose from blower to splitter valve, the valve and pipeing to both sides, and get a rubber plug cap for the vaccum valve to block it off and you just cleaned up your engine compartment.
if your running headers, you'll either be running hi-flo cats or none at all so you really don't need that system except for helping it pass emisions testing. the system pumps air into the exhaust to help the cats burn off excess fuel
Good call sometimes we spend a little mre money to get things the rite way but its the rite I would of bought ur headers but I just bought some hookers but dnt worry we all make mistakes especially when building a beauty of a LS block or a F-Body
Had the same problem, took off a piece of heat shield and made a blockoff plate using the gasket as a template. Also used a freeze plug for the intake, no leaks from either.
Took a whole 5 minutes to solve my 3 day problem lol
if you need block offs just to get going... 2 cents can do it. cut the flange end off your air hoses, place a penny over the hole on the header side...plcae the flange you cut off on top of it, bolt it down. blocks are done and at least get the car driveable, not ideal in terms of looks.
i made the same mistake with my headers, but idgaf. i made block off like that when i removed air/egr from my car. they've been in use for over 5 years and do not leak. didn't cost a damn thing to make.
