Knock after clutch/header install - LS1TECH
Thread Tools Search this Thread
Old 05-07-2012, 05:59 PM   #1
Martin HD-28's Avatar
Default Knock after clutch/header install
I just went from a stock clutch/pp/fw to a TEX OZ-700 and SLP LT's to KOOKS LT's. ONLY when I go from a stop and pull off in first, I hear a knocking from, it seems to be, the clutch area. It sounds more like something hitting something else than just a popping/knocking though. I torqued all bolts to spec so i'm not sure what to make of it.....Ideas?
Martin HD-28 is offline   Reply With Quote
Old 05-08-2012, 04:25 PM   #2
Anyone???? I'm thinking maybe the exhaust bracket? Motor mount?
Old 05-08-2012, 04:33 PM   #3
MM98's Avatar
Possibly new clutch chatter.
MM98 is online now   Reply With Quote
Old 05-08-2012, 05:16 PM   #4
sepsis's Avatar
After I installed my headers, they smacked the floor board on the drivers side. I had to make some room for movement with my air hammer.
sepsis is offline   Reply With Quote
Old 05-08-2012, 07:32 PM   #5
1999FirehawkLS1's Avatar
Quote:
Sounds like its time for Poly Motor mounts..ever car went put LT's on we always do the mounts cause of this reason.
1999FirehawkLS1 is offline   Reply With Quote
Old 05-08-2012, 08:02 PM   #6
I went from SLP lt's to Kooks lt's strictly for the clearance, i've probaby got another 2 solid inches of clearance with the kooks. I mean they fit SOOOO good and tight underneath so Sepsis, you may be right. However, I remember telling the gus helping me with this that the Kooks y-pipe didn't fit very well to the exhaust bracket so that's another thing i've gotta check. Motor mounts would be my next mod I reckon since i've got such a large cam.... Thanks for the response guys.....
Old 05-08-2012, 08:04 PM   #7
MM98, there's no way this noise i'm hearing is any kind of chatter....I'm sure we torqued every bolt to specs and it's a Tex OZ-700 which isn't supposed to come with any chatter. Thanks though.
Old 05-10-2012, 05:47 PM   #8
Tex OZ-700 clutch do have alot of chatter least the couple cars ive rode in w them compard to the monster I had when I was M6
Old 05-10-2012, 07:44 PM   #9
My Official Textralia OZ700 Z-grip Review
The above is the average review i've read on the clutch. I had to leave town so it'll be another week or so before i can get my hands on it to figure it out but i'll keep this thread updated.....Thanks for the response...
Old 05-10-2012, 09:23 PM   #10
Problem?
Dr Tran's Avatar
I would all but put money on the Y-pipe hitting the floorboard.
Dr Tran is offline   Reply With Quote
Old 05-10-2012, 10:19 PM   #11
I thought that since the y-pipe didn't fit the exhaust bracket so good (it's offset to the right) that that would be the problem, but I put a rubber pad between the two and I still got the knock so i've gotta rule out the exhaust bracket knock (although i've considered the option that I put the bracket back on backwards). The kooks fit SO well that i'm betting it's hitting something but I haven't track it down yet.
Old 05-10-2012, 10:24 PM   #12
Problem?
Dr Tran's Avatar
My drivers side of the Y was hitting, not passenger side.
Old 05-10-2012, 10:36 PM   #13
sepsis's Avatar
Quote:
I installed poly mounts with my headers. My header collectors are 3 1/2 inches. Most are 3" that's why I think it was hitting the floor.
Tags
2012, camaro, cluht, clutch, engine, firebird, header, hitting, instalation, install, knock, knocking, speed, ss, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
