98-99 exhaust manifolds vs - 02'ish manifolds - size difference?
I have a 2002 Camaro that I purchased some turbo plumbing for. The passenger side of the plumbing connects to "a factory LS1 fbody exhaust manifold". I no longer have my factory manifolds and will have to buy one for the passenger side. Before I do, I wanted to know if the overall geometry of the manifold changed over the years because if so, it might affect what I need for this plumbing. I've seen pictures of the 2 manifolds side by side, and there are slight shape differences, but I couldn't tell if the flange would be in a different spot between the two types. Would you be able to pop a 98 manifold in place of a 2002 and connect it to the same factory Y pipe with no fitment issues?
Thanks!
Thanks!
the pass side is definitely different between 99 and 01+. not sure of 00. i replaced my manifolds with ones off an 01 car and had to have the y altered on the pass side in order for it to work. i believe the newer manifold exits farther down than the older one, but don't quote me on that.
