Pcv routing help
Old 05-15-2012, 06:06 AM
Pete91's Avatar
Default Pcv routing help
The way my system is set up is I have the pcv valve in the driver side rear valve cover. Then from there it runs around the motor to the top of the catch can. Then the front of the passenger cover gose to the fitting on the throttle body and the lower fitting on the catch can goes to the lower part of the intake. Does the location of the pcv play a role? Anyone know the p/n's for the fitting that goes in the rear of the driver side cover. I currently have the pcv in it. Also anyone know the the number for the rubber bushing type that normally houses the pcv. Thank ps with this all hooked up the car wouldn't idle. So it is hooked up now the fitting on the tb is blocked and the top of the catch can goes to the front ps fitting and runs fine.
Old 05-15-2012, 07:08 AM
DONAIMIAN's Avatar
Search for a thread titles "is my PCV routing ok" it will answer all your questions.
