help installing a maf
Does anyone have a pic of a GM Z06 85mm install on ur LS1 I bought one for really cheap I bought the harness adapter but I can't seem to figure out how to install it my old maf and housing are different so any pics or instructuins will help again maybe I'm over thinking it but I cant see to figure it out anything that would throw me in the rite directions will help
I can't believe no one here has ever installed a Delphi GM 85mm Z06 maf on a LS1 if in this site or forum no one can help do u guys now what forum or site I can go to? CamaroZ28.com? Anything?Anyone?
You'll need a coupler, rubber or preferably reinforced silicon. The coupler will need to fit over the end(on the outside) of the lid.
IMO, to benefit from the 85mm MAFS you need to have the car tuned for it. Even then the gains are minimal if you're stock or close to it.
I got one on my car I will take some shots of it in a little while.When I bought the car it had it on there.i also have a 85mm throttle body.If you are using the stock throttle body you will have to get a reduced bellow to fit your throttle body.
