Energy Suspension Motor mounts: New? No clam shell?
Old 05-21-2012, 09:38 AM
ANTICOP RAM AIR's Avatar
Default Energy Suspension Motor mounts: New? No clam shell?
Saw they have a different style mount that looks like it doesnt use the OEM clamshell setup. Anyone use these? are they any good?
Old 05-21-2012, 09:51 AM
Rare96LT1Formula's Avatar
Are you talking about the poly mounts? That's what I have and they definitely need to be inside of the stock clamshells. I'm not aware of a solid motor mount that they make.
Old 05-21-2012, 09:57 AM
It is this mount..
Old 05-21-2012, 10:02 AM
Interesting...
Anyone use these yet? Looks like a cross between solid/poly.
Old 05-21-2012, 10:05 AM
babbage1109's Avatar
That doesn't look like its for our car. You'd need another piece attached to that to mount the engine.
Old 05-21-2012, 10:10 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Looks like LS swap mounts to me
Old 05-21-2012, 10:27 AM
these were just web pictures.. theyre on the energy suspension site and they talk about their "new" design with the built in locking feature...
try this page... their fitment guide/catalog is down for upgrades for a week now but heres the page..
http://energysuspension.com/products/Motor-Mounts.html
Old 05-21-2012, 10:47 AM
lsx74camaro's Avatar
Those are based on old style chevy mounts, i converted my clam shell to these for my ls swap and bought plates separate.Back it the day (early seventies) these mounts were separating engines were lifting from frame, i think there was lawsuits against GM , so GM came up with the clam shell mount then if the rubber broke the shell would prevent the engine from moving. energy suspensions mount has an interlock inside to prevent seperation. I like the old style better, lighter weight more compact.
Old 05-21-2012, 10:48 AM
moroso makes a solid version of these.
Old 05-21-2012, 11:02 AM
Ok, so what are the options for a poly mount for our engines..? Im finishing my LQ9 up and need new mounts...
Old 05-21-2012, 01:53 PM
3-1151G direct replacement
Old 05-21-2012, 02:18 PM
other than that one?
Old 05-21-2012, 03:05 PM
I'd do solids but that's me.
Old 05-21-2012, 03:56 PM
so no other suggestions? Who else makes poly mounts?
Old 05-21-2012, 04:24 PM
99Bluz28's Avatar
Prothane also makes the clam shell inserts.
http://www.ws6project.com/user_stor/...-motor-mounts/
The ES mount are basically the same, and cost a little less.
http://www.ws6project.com/user_stor/...oducts_id=4290
Old 05-21-2012, 07:32 PM
If you want to use the old style mounts get ready for some fabrication, with an older camaro ,i made a frame mounts to use them for my BBC when i converted it to lsx i just had to buy the plates cause an lsx uses a 4 rectangle mount and a traditional chevy engine uses a 3 bolt triangle mount thats farther ahead.
Attached Thumbnails Energy Suspension Motor mounts: New? No clam shell?-kgrhqfhjdee-py9qdy-bpt33yfuz-60_12.jpg
Old 05-21-2012, 08:11 PM
Blk98Vert's Avatar
What do you have against the clamshell?
Old 05-21-2012, 08:18 PM
^ nothing really, just looking for other options.. Im not considering solid mounts... I heard they raise the motor a bit, change the angle and could cause ypipe contact, resonate vibration more and also make a trans removal a real pain in the ***...
Old 05-21-2012, 10:05 PM
Motivative mounts haven't done any of those things to my car. Lol. There aren't many options out there. 4 company's do solids. Or you have to do the clamshells
Old 05-22-2012, 12:55 AM
99Bluz28's Avatar
If you want something like the Motivative mounts, except in aluminum look at the UMI mounts.
http://www.umiperformance.com/news/w...ounts/2323.jpg
Quick Reply: Energy Suspension Motor mounts: New? No clam shell?
