4 cylinders missfire....HELP!
Old 05-26-2012, 01:21 PM
streetknight2's Avatar
Default 4 cylinders missfire....HELP!
Friend has a 99' vette. He went to the track last night and on the 3rd pass the car nosed over and started skipping. He was spraying the car at the time. He was able to limp the car home. The car skips badly all the time but will run. He changed plugs, no change and started pulling plug wires one at a time, but there's no change when you pull all the passenger side wires. Getting NO spark what so ever on that side.
Any ideas?
TIA
Old 05-26-2012, 02:41 PM
Moderator
jimmyblue's Avatar
I'd be looking at the common high side (IGN) power
feed to the coil packs, and the injector common
power.
Old 05-27-2012, 12:18 AM
fastazzls1's Avatar
^ agreed look for all common problems on bank 2 if it affected both banks i would look else where rule out all of the possibilties and try not to jump to conclusions and the car will be fixed good luck bro
