breather questions
breather questions
ok so i have a breather on my valve cover. PCV delete. i'm getting tired of the oil mist and smoke. now what if i took the breather off, run a hose to one of these
would it work? there would still be a breather , but the oil mist would get caught in the catch can instead of misting out of the breather
so you currently run no catchcan with your pcv delete setup? you should. and why not take the valve cover off and weld a piece of metal covering 3/4ths of the whole so it can act as a baffle to stop the filter from getting soaked.
