Camaro SS Hurst Shifter?
Old 06-10-2012, 04:02 PM
Mrjockos's Avatar
Default Camaro SS Hurst Shifter?
Have a Camaro SS with a leather wrapped Hurst knoob, was this an option on the Camaro ss 1998? What is the name of this option if it is one?, The codes on my SLP door sticker has faded.
Old 06-10-2012, 05:25 PM
mean_greenZ's Avatar
It came in 96-97 ss cars and an option for z28 and ss cars from 98-02. Rpo code BBS.
Old 06-11-2012, 06:21 AM
Mrjockos's Avatar
Okey should this coupe appear on the SLP sticker or with my other rpo codes below my vin number, because my SLP sticker has fadeded away cant se the codes, its just all blank.
Old 06-11-2012, 03:42 PM
It will be on with the other Rpo codes. Also you can call slp and give them your Vin and they will tell you all the slp options it came with and what car number it is.
Old 06-13-2012, 04:17 AM
2win_SS's Avatar
Do u have short stick? If u do and it hits console in 2nd then it's STOCK... Not Factory Hurst...
Old 06-13-2012, 03:42 PM
John Kopek's Avatar
the Hurst in my 2000 T/A was an option, the guy I bought it off of gave me the original window sticker from the car. It says $325. Mine doesn't hit anything in second, could be different being pontiac. Not sure...all I know is I gotta get the plug in to disab;e the skip shift...annoying
Old 06-13-2012, 11:39 PM
2win_SS's Avatar
^^^ Short Stick and Skip Shift delete was 1st mods on my car.
Old 06-18-2012, 03:08 PM
Mrjockos's Avatar
Here is what my shifter looks like? Think it's a SLP Option, I can nearly see it on my faded SLP door sticker. ? what do you think? IS it a Hurst shifter?
Old 06-18-2012, 06:05 PM
jonisalex's Avatar
Holy huge picture batman. Anyways yup, that's the hurst shifter option.
Old 06-18-2012, 10:06 PM
2win_SS's Avatar
DAMN!!! I've seen sum worn out shifter *****... I thought my buddy had the worst looking shifter... You take the cake after seeing that pic... Time for a new one buddy...
Old 06-18-2012, 11:35 PM
iroczracer07's Avatar
I'm with 2win ss. That shifter looks really used, lol
Old 06-19-2012, 03:26 AM
2win_SS's Avatar
^^^ USED isn't the word that would best describe this shifter ****... Looks like someone took a grinder to it... Or chewed on it lmao...
Old 06-19-2012, 03:59 AM
poloaa009's Avatar
Thanks for all the reports guys, nice to hear that.
Old 06-19-2012, 06:30 AM
Mrjockos's Avatar
Hehe, I have ordered a new one, "old school" style hurst knoob, how do you loose this hurst leather knoob from the stick? It's stuck like hell, can't see any clips or something in the front of the knoob and cant twist it to loose....How does it sitt?
On a new Hurst leather knoob on ebay they describe it like this:
"Hurst black leather shift **** for OE T56 shifters (M16 thread). Embossed "H" logo. This would be factory installed on 96-02 Camaro/Firebird cars with the factory installed Hurst shifter. Simple installation, just tighten by hand."
I cant twist my, then i will break my shift stick^^
Old 06-19-2012, 06:56 AM
jonisalex's Avatar
Try heating it up with a hair dryer under the ****.
Old 06-19-2012, 07:16 AM
BigBirdLS1's Avatar
My 02 SS had the hurst shifter and when I was changing it out I realized the the Hurst **** wasn't a thread type. Although my shifter looked different than the picture. Mine was alot shorter.
Either way I got the short stick that UMI makes you lift up the shift boot and there's 2 bolts. Put the UMI stick on it then just thread the **** of your choice works perfect IMO. Hope this helps.
Old 06-20-2012, 02:05 AM
2win_SS's Avatar
^^^ you wnt break your stick... Trust. Just get a good grip and turn counter clockwise... Buy a ShortStick anyways. U dnt want that one...
Old 06-20-2012, 02:59 PM
Mrjockos's Avatar
Finally I have been able to swap my shift knoob, The Old hurst leather knoob, was complety stuck, hade to cut and slice up the leather knoob, and inside there was some plastic ****,
even then we couldnt get the knoob of, so we hade to cut the plastic down piece by piece with a knife.
Finally it was loose, and there we found the problem, sombody had put loctite, in it Clever guy....
Thank you very much guys for all your help and tips!
Old 06-20-2012, 08:56 PM
2win_SS's Avatar
^^^ they come stock with loctite from factory I believe. You just had to break it loose. You goin with a short stick? Or stock?
Quick Reply: Camaro SS Hurst Shifter?
