Elec cut/out install
Car is 2000 SS with LT's and no/cats 3 inch CB.
Looking at a QTP oval low profile cut out.
1. how are you guys running the wires for power?
2. Where are some locations for the switch ?
3. Is the QTP top of the line, or.........
Thx for the help.
WC
Thx for the help.
WC
You run the wire up in the drain plug right by the intermediate pipe. You snake it under the carpet to the armrest. You can get to the drain plug when you pull the rear seat cushion out. Its 1 bolt holding it in.
After its in the arm rest you can mount the switch anywhere you like. Just tap for power on any ignition wire and any ground source.
You might want to get out wireless remote. Makes the install easier since you do not have to drill and mount the toggle switch. Just have to tap for power and ground for the receiver box.
Here is the part numbers for your reference.
QTEC30CP-3" Valve, Wiring, Toggle Switch, Stainless Steel Y Pipe
11300-Optional 3" Turndown
10900-Optional Wireless Remote
And of course we are top of the line.
Over 70,000 Electric Cutouts Sold to Date!
But you can make that choice for yourself by calling us at 973-513-9955. Or you can try to get other people to answer there phone and respond to emails.
Keep it loud!
