stock 98 heads question
Yes, '98 heads had a different casting than the '99+ which is said to be inferior. Also, I believe the intake ports on later heads were machined a little versus the early heads which were left as cast
Nothing you will notice. Also once ported they flow the same as the rest. If anything get some 243's because its a complete waste of time and money to swap an ls1 head for an ls1 head.
