90mm tb coolant bypass question
Old 06-20-2012, 06:37 PM
andy-lswon's Avatar
Default 90mm tb coolant bypass question
Just to make sure, I'm guessing the same bypass kit can be used on a 90mm nick williams as you would use with the stock tb? I'm gonna use the bmr kit to save me the hassle of finding all the parts even though it'll cost a little more
Old 06-20-2012, 08:52 PM
2win_SS's Avatar
Just run a hose straight from the radiator to the coolant pipe from the head. Cheaper plus you will only have 2 spots to worry about leaks instead of 4!
Old 06-20-2012, 09:49 PM
T76s10's Avatar
i seen people just cut the bypass off and get rid of it in general. its useless to even use it.
Old 06-20-2012, 10:10 PM
2win_SS's Avatar
^^^ do u mean cut the lines on the TB? ya ive seen that.... Not getting rid of the line from the head going to rad. And it is there for a reason. How useful is it? I'm not sure. But I dnt run one.
Old 06-20-2012, 10:23 PM
T76s10's Avatar
yeah off the tb not the one coming off the head lol. even though im sure someone out there probably has tried blocking the one off from the head.
Old 06-20-2012, 10:46 PM
2win_SS's Avatar
^^^ ya he wants to run a by-pass so I suggest instead of the barb fitting and hose clamps just run a hose straight from the head to the rad. Yes you can cut lines but if u ever wana sell the tb someone might want the lines connected. To each his own
Old 06-21-2012, 11:26 AM
andy-lswon's Avatar
Thanks for the help fellas
