whats the bet way to clean engine out after head removal?
Old 06-25-2012, 08:19 PM
Floorman279's Avatar
Default whats the bet way to clean engine out after head removal?
just pulled the head for a bad head gasket.....when i removed it, 2 cylinders are now filled with coolant, and lots of dirt inside the cylinders, as well as the lifter trays.....i removed the trays, and there is still some dirt underneath.......not sure if air is the best way to clean this, since i obviously dont want it getting inside where the cam is.......is air my only option tho?
Old 06-25-2012, 09:25 PM
reeperz28's Avatar
What i did is dry the cylinders out as best i could with paper towels, then for lifter trays and lifter bores i really could not think of anything but cheap oil to pour on it then just let it drain out the oil pan drain plug. For head bolt holes i got this idea from another forum member.
Old 06-25-2012, 09:29 PM
reeperz28's Avatar
Medical mouth swabs from local pharmacy. Worked great but need a hell of alot of them like at least 40 for each head set of bolts to get completly dry thats just one method im sure theres more or better.
Old 06-25-2012, 09:34 PM
LS6427's Avatar
Won't a blast of air into the holes get all the water out, then whatever is left will evaporate.???
Old 06-25-2012, 09:42 PM
reeperz28's Avatar
I blasted the coolant best i could with what i had (large air compressor and blow gun), car has sat for eight months and just did the swabs yesterday and still was sitting coolant down at the bottom of the holes.
Old 06-25-2012, 10:49 PM
i kinda like that pour cheap oil idea..........think im goona do that as far as the dirt in the lifter bores.........i mean i got most of it out, i mean there is only a tiny bit of dirt left.......will that be ok since its al very fine then just change the oil in 50 miles or so and new filter?
Old 06-26-2012, 06:49 AM
reeperz28's Avatar
Oil filter will catch what you dont get. That is what im going to do when all my heads and cam are done drive around on the mobil one , then change to royal purple when time for dyno.
Old 06-26-2012, 07:22 AM
okay so as long as theres not much ill be okay i guess.........also, how watertight are the cylinders? when i left my buddies place lastnight,, there was a lot of coolant in each of the cylinders......shoulda gotten it out then but didnt think of it........is the antifreeze goona be able to get past the rings and into the oil if it sits there another few days? or would it be best to change the oil before startup? now granted assuming the rings on my 95000 ls1 are still good
Old 06-26-2012, 08:52 AM
thunderstruck507's Avatar
I twisted paper towels and poked them into the holes. Tried blowing them out and there was still water in them.
Took quite a few towels to soak it up. I poked them in and let them soak like a candle wick then pulled them and did it again until they came out dry.
Old 06-26-2012, 11:57 AM
reeperz28's Avatar
The small amount of water/ coolant that gets bye is not going to hurt as long as you let it drain when you do an oil change before startup after the new head is on and gasket. If a large amount does get bye it will drain out with the oil in the crankcase. Just dont turn over the engine without changing the oil first when you put the head back on.
Old 06-26-2012, 08:55 PM
yea i shoulda taken car of that.....i think im goona blow everything out with an air gun........then take car of all the bolt holes........then pour oil through the lifter bores, then change it......im up to like 240 dollars invested in this.....all because i overtightend a head bolt and it snapped in the head....also, 2 bolt holes got cross threaded stupidly....
removed bolt and heli-coil 2 bolt holes- 100
gasket and bolts- 75
broke coolant temp sensor- 12
new seprentine belt(think its slippin) 25
fuel line tool- 4
more effin oil and filter -35
rocker pedestal-7
so like 250........o and lots of scratches and cuts
Old 06-26-2012, 08:56 PM
o and when installing lifters, do i keep them locked in the lifter trays, then when i bolt the tray down push the lifters down until they contact cam?
Quick Reply: whats the bet way to clean engine out after head removal?
