Help with air lid
Old 06-26-2012, 09:03 AM
redtaws6's Avatar
Default Help with air lid
I have a 2000 pontiac trans am ws6. I just installed a tb, below, mafsensor,and slp air lid.
When i go to lock the slp air lid in place it doesnt fit in the slots and hangs over the front of where it should be seated about a half inch.
I need to know if any else has had this problem. Also what i need to do to fix it.
Old 06-26-2012, 09:06 PM
Pontiacerator
RevGTO's Avatar
Make sure the neck is all the way back against the ridge on the MAF and work the prongs all the way into the slots and it will fit. You just have to work it and fiddle with it.
Old 06-26-2012, 09:11 PM
2win_SS's Avatar
Well 1st off make sure all parts are as far in each other as possible. Example. Bellow all the way on TB. MAF all the way in bellow. MAF all the way in lid. Getting the MAF in the lid is hardest. Use hair dryer to heat it up. Then u will be fine.
Old 06-26-2012, 09:17 PM
Pontiacerator
RevGTO's Avatar
Yes, you put it better than I did ...
Old 06-26-2012, 09:20 PM
sepsis's Avatar
LOL you said "fiddle with it." lol
Old 06-26-2012, 09:23 PM
notfastenoughyet's Avatar
+1 for checking for snugness
Old 06-29-2012, 09:18 AM
redtaws6's Avatar
k did that. it helped a bit but still hangs over. Im thinking im going to have to trim me below down.
Old 06-29-2012, 09:36 AM
raysadude's Avatar
What kind of lid you got? Stock maf?
Old 06-29-2012, 10:04 AM
Z28RS's Avatar
Hey, dude! Wow, it sounds like you just got yourself a pretty nice setup there — congratulations!
I've had a very similar setup on my Camaro for nearly ten years, and I've been delighted with it. In addition to the parts that you have, I also have a velocity stack. To make sure that everything fit properly in my car, I had to trim about .25" off of my bellows.
However, before you do any cutting, check to see whether or not the four "prongs" on the back of your air lid are seated in their respective holders on the radiator shroud. If all four are snugly pushed back in as far as they'll go, you may have a major fitment issue.
But, if the prongs aren't even in the holders, and assuming that you've followed "2win_SS's" good advice, you may wish to trim a bit off your bellows as I had to so that your lid will slide all of the way back. Be sure to measure carefully before you make any cuts; you may not need to take off as much as I did!
I wish you the best of luck with your project, man. And I hope that you enjoy the benefits of these pieces as much as I have!
Old 06-30-2012, 04:36 AM
My6speedZ's Avatar
Take you time and heat it up well before you start cutting, it should line up if you can get everything pressed together tightly. Start at the throttle body and work you way to the front.
Old 06-30-2012, 10:59 AM
DNTBJELOUS's Avatar
I 2nd Z28RS for checking the 4 tabs that must go into the slots in the back of the lid. I had this problem when throwing all my stuff back together quickly once.
Old 07-05-2012, 10:02 AM
redtaws6's Avatar
The tabs line up they just arnt seated where they are supposed to be. Where did you get the velocity stack at z28rs.
Old 07-05-2012, 01:01 PM
hiram007's Avatar
X2. The MAF in the lid was definitely the hardest part.
Old 07-06-2012, 09:01 AM
raysadude's Avatar
That's weird, my. 85mm MAF snug in real easy to ftp 98mm. That's the reason I asked what kind of lid and MAF does OP have
Old 07-06-2012, 10:59 AM
2win_SS's Avatar
^^^ he said he has SLP lid.... I assume the stock MAF... The MAF into lid is hard part... As far as the rest of the swap "So Easy... A cave man can do it"
