are they makin the fast 92 intake again
Old 06-29-2012, 08:04 PM
spiro27's Avatar
Default are they makin the fast 92 intake again
was on a website that sells the fast 92mm intake for 840. they say that its back and is being made again. is the fast 92mm intake better than a 102 . i have seen some treads on here that say the 102 needs alot for etra parts to fit and seen some guys say the loose power with it.. my car is a 01 ws6 with mild cam and tfs 215 heads and all bolt ons. would i be better wtith the 92 intake 02 102 the price difference is 150 between the 2. is the fast 92 reqire less work to install and should i run a 92mm tb. thanks for help and info.
Old 06-29-2012, 08:09 PM
Pseudonym's Avatar
The 92 is back, available in black now instead of primer gray. I wouldnt say it is better, but you can put your stock fuel rails on the 92. I have the 92 on my 402 and I love it. Put the 92mm tb on it. I suggest the Nick Williams tb.
Old 06-30-2012, 08:23 PM
2win_SS's Avatar
^^^ I agree 100%. go with 92 so u can swap fuel lines and injectors right over. A +1 for the NW TB. 2nd choice would be PTM from TSP. dnt go with FAST 92. Goodluck buddy
Old 07-01-2012, 08:30 PM
spiro27's Avatar
do i have to get valey cover bolts with shorter heads like the 102. if i get bigger fuel rails will it fit on the 92 intake. what is need to make the 92 intake fit in a 01 trans am ls1.
Old 07-02-2012, 09:14 AM
2win_SS's Avatar
Yes you need the Burton head valley cover bolts. I forgot to
Mention that. And you have a 01 so You already have LS6 coolant line. Easy swap. What TB you guna buy? I vote NW/PTM
Old 07-02-2012, 07:18 PM
NEXRACE's Avatar
x2 on getting the fast 92 intake. I like the new black ones but a deal on a used gray one would not be bad.
Old 07-02-2012, 10:03 PM
SStressin's Avatar
yes they rereleased it last week...going to be ordering mine hopefully in the next week or 2.im very excited!
Old 07-03-2012, 08:26 PM
spiro27's Avatar
i was thinkin fast 92 or nw 92. want to upgrade my fuel rails will the fast fuel rail kit fit or is it only for 102. what maf sensor should i get? will my bellow fit over and what lid too.
Old 07-03-2012, 08:33 PM
baalic's Avatar
man, 950 bucks for like what? 12 hp??! Jeezus, but it does look sexy...
http://www.compperformancegroupstore...Category_Code=
Im sure a sponsor may have it too, maybe for cheaper?
Old 07-03-2012, 09:28 PM
2win_SS's Avatar
^^^ like I said I vote Nick Willams 92.... Save sum cash plus it is a piece of Art... You do not need fuel rails for the 92... You can use stock. Only difference you will see in changing fuel rails would be the appearance.. No HP gain. I would get a GM 85MAF. and you can use SLP bellow for all of this... Any lid. I vote FTP or SLP.85 MAF nt fit into SLP lid with a reducer sleeve thing.... FTP lid can fit a 85maf. Goodluck
Old 07-03-2012, 09:45 PM
hiltsy855's Avatar
SDPC Fast 92
