What kind of tool to port a FAST intake?
Old 07-04-2012, 03:40 AM
Bramlok's Avatar
Default What kind of tool to port a FAST intake?
This would be just for some basic head port matching. What works best? Those sandpaper rolls on a dremel or something that cuts harder?
Old 07-04-2012, 04:27 AM
The Scammer Hammer
dr_whigham's Avatar
Interested as well. I know Tony uses carbide, but no idea what bits.
Sandpaper rolls seemed to melt the plastic rather than grind it out, in my experience.
Old 07-04-2012, 10:11 AM
BrntWS6's Avatar
I used the stone bits that come in the Dremel kits.
Old 07-04-2012, 01:37 PM
Bramlok's Avatar
I have some stone bits. Do they tend to clog up and get coated with plastic or do they stay fairly clean?
I'm not sure if I have the experience like Tony to use carbide bits. I'm sure those would chew through plastic fairly quickly for a first time porter like myself. I wanted a bit that I could work with nice and slow while taking my time.
I might be better off just sending it to Tony and have him do it.
Old 07-04-2012, 03:24 PM
BrntWS6's Avatar
They did not clog up as all. It was my first time porting an intake too and they worked well for a beginner.
Old 07-04-2012, 03:32 PM
Bramlok's Avatar
Sounds good. Thanks for the info! I'll give those stone bits a try.
Old 07-04-2012, 05:40 PM
garygnu's Avatar
get small diameter bits to deal with the corners.
Old 11-07-2012, 12:24 PM
themealonwheels's Avatar
Bump, Bramlok, did you do this? How did the dremel/stone bits work out? Any before/after pics?
Old 11-07-2012, 01:38 PM
thunderstruck507's Avatar
I used sandpaper rolls for the Dremel at a somewhat low-medium speed. No melting or clogging and worked great.
Old 11-07-2012, 04:56 PM
99Bluz28's Avatar
Sanding rolls work great, you just have to start at a slow speed then work it up.
Old 11-07-2012, 06:22 PM
3rdCoastPowerSports's Avatar
i agree
Old 11-08-2012, 08:48 AM
That's what I did, the material of the Fast came off in shard like pieces rather than fine dust or melted ***** from what I remember. It was insanely easy to work with.
Old 11-08-2012, 02:13 PM
Bramlok's Avatar
I used a combination of both the stone bits and sanding rolls. Kept it at low and medium speeds. It turned out pretty nice. I port matched it to the heads and smoothed down all the rough surfaces. It took me about a weeks time working on it a little bit everyday. In that week I spent maybe 7-8 total hours but went really slow and took my time. Sorry I didn't take any pics mostly because it was such a mess when I started the grinding with plastic shavings everywhere.
Old 11-08-2012, 04:40 PM
omc8's Avatar
How far are you guys going up into the runners and how much material are you removing.
Old 11-08-2012, 06:29 PM
bayer-z28's Avatar
I'd say carbide, just keep the speed down. Finish with sand rolls on a die grinder; also keeping the speeds down. Helps to limit them by limiting the air coming into the tool.
Old 05-28-2015, 10:17 AM
scotty2000ss's Avatar
Bump for anyone that took pics while doing this.
Quick Reply: What kind of tool to port a FAST intake?
