what new bolt do i need with the ASP pulley?
Old 04-01-2004, 05:25 PM
Stone0fFire's Avatar
Default what new bolt do i need with the ASP pulley?
instructions say i need a new bolt.
where can i get that bolt?
will lowes carry it?
i really dislike home depot.
their bolts break easier than the ones that attach our stock y-pipe and ex. manifolds.
anyone have the specs on this bolt so i can tell the hardware guy?
Old 04-01-2004, 05:36 PM
2xLS1's Avatar
12557840 at a GM parts counter for ~$3-$4 or ARP makes one for around $25 that is reusable. The GM bolt is TTY and should only be used once. You will use the old crank bolt to seat the pulley on the crank then use the new bolt for the final assembly.
Old 04-01-2004, 09:52 PM
NastySSoo's Avatar
Ditto what 2xLS! said. And dont forget the loctite!!
Old 04-02-2004, 04:52 PM
now i am even more confused.
i got the bolt from GM for a bloated $4.50
now its on special order and should arrive monday.
my Q's are=
what is TTY?
what is loctite?
thanks for the part number =)
Old 04-02-2004, 04:58 PM
HumpinSS's Avatar
Torque To Yeild meaning once you strech it that bolt cant be re-used. and Loctite is used on bolt threads to keep the bolt from backing off
Old 04-02-2004, 05:03 PM
thanks!
Old 04-07-2004, 03:51 PM
navy02ws6's Avatar
Does anyone have the part number for the ARP bolt? I can't seem to find it on their website.
Old 04-07-2004, 03:56 PM
2xLS1's Avatar
http://www.thunderracing.com/catalog...vid=3&pcid=111
Old 04-07-2004, 04:01 PM
navy02ws6's Avatar
That was quick. Thanks!
