LM2 Install Help!!!
Old 07-08-2012, 11:27 PM
Dead Hook's Avatar
Default LM2 Install Help!!!
I pulled out the Flowmaster cat back that the PO had installed and I started to piece in the LM2. I'm to the part where you connect the welded bracket to the exhaust hanger on the passenger side. I'm guessing that I don't have the stock mount anymore. Take a look. Where do I get a stock mount? I'm stuck and frustrated as hell. Thanks.
Ignore the leaking rear end, I am also installing a "Ultimate" girdle cover.
Old 07-09-2012, 12:24 AM
Fasrnu's Avatar
local muffler shop could fix you up a hanger quick. or maybe make something that will bolt on
Old 07-09-2012, 12:28 AM
The Scammer Hammer
dr_whigham's Avatar
You need the hanger that bolts TO the catback, and that SLIDES into that hanger.
Should look similar to this
Old 07-09-2012, 12:44 AM
Dead Hook's Avatar
Ok, I don't have that. Does anyone have a picture of the actual stock one. Even better would be pictures with some basic measurements so I can have one made.
Old 07-09-2012, 02:11 AM
bww3588's Avatar
Gm dealer can get you one for less than 10 bucks if I remember.
I had this exact problem installing my lm1...
That was almost 10 years ago tho. Prices may have went up since then.
Old 07-09-2012, 08:54 AM
hiram007's Avatar
definitely missing the hanger, that sucks, wonder how things like that happens sometimes. Shouldnt be too hard for a muffler shop to get you one or you could go to GM for it.
