Stall size for Ms3 cam for DD
Alright so I'm having a lil trouble on deciding what size stall and what converter to go with for my 01 SS. All the posts that I've come across have people saying that they would need to know the mods of the vehicle before they can "really" help them. So I've put a list together of all my mods(I think). This IS my DD but I WILL be at the track every other weekend or so.
I understand I went with a big(er than reccomended) cam for a dd and I'm ok with that. Just wanna know what will perform better light to light, on the track, and in-between
Thanks
Performance: LS1 out of an 02 Vette, Magic Stick v.3 cam w/112LSA, PRC .650" dual vale springs w/titanium retainers, seals and seats, TSP Hardened pushrods, SLP Double Roller timing chain, SLP Fully ported oil pump,Yank SS 4000 stall torque converter, TCI flex plate(need to order), Comp lifters kit, BBK Performance 85mm throttle body, Taylor Cable TB spacer, SLP Flowpac intake package(whisper lid, smooth bellow, forced induction, K&N filter), headman headdress, pacesetter performance off-road Y pipe, SLP Loudmouth ll exhaust, 3:73 gears, Jet performance mass airflow sensor, Functional after factory Fiberglas SS Hood.
Suspension:
Hotchkis double adjustable panhard bar, Hotchkis trailing arms with relocating brackets, SLP lowering springs, and Polyurethane bushings.
Thanks
Suspension:
My bad. I put that in there bc that's what I was thinking about getting. Haven't purchased anything yet. But ya on the TSP site, they reccomens a stall of no less than 3800... But I've got a couple people telling me they wouldn't go any higher than 3000...idk what to do haha
If you're worried about DD and having too big of a stall, check out this video.
4000 Yank on a 2002 Z28.
http://www.youtube.com/watch?v=f3aXFIf7jIs
SS4000 would be fine naturally aspirated or the PT series as stated above.
Yank makes great general purpose converters, Circle-D and FTI will do more custom jobs so you could talk to them as well and get their input. Chris (Circle-D) and Greg (FTI) are both excellent guys to talk to and are really helpful. I wouldn't have an issue going with either of those or Yank if I didn't feel a custom built one would be better for me. I personally am opting for FTI because a speed shop kinda close by has a package deal, the converter, install, and dyno/street tune for $1350 and from what I've seen around here, unless you're doing it yourself you can't beat the price.
For reference, Yank SS series are $745, Yank PT are $795, Circle-D 245mm Pro Stage I is $775, and FTI runs $700 for their SRLS series.
To answer your tightness question real quick, in his application the 3600 is "tight" meaning with the gears and STR of the converter it is easier to get moving off idle at tame throttle. Going "looser" usually by getting a higher stall speed (although it is more complex than that) means that it takes a little more rpm to get the car to start pushing forward. A lot of things affect the tight/loose state of a converter: car weight, STR, stall speed, gears, and engine modifications, i.e. heads/cam
I've also heard great things about PTC, check them out too if you want OP. Grr, correct me if I'm wrong but I don't believe that that $425 is billet is it? I'm aware that billet isn't necessary for all applications, for normal daily use non-billet is quite acceptable, I just want to make sure the OP knows thats why the price would be different compared to the prices I quoted above which are all billet.
I only mentioned the PTC being non-billet because he was considering a Yank SS which is billet, I didn't want him to think that the $425 converter was billet also, but yeah pretty much all high performance converter companies have more budget minded converters.
That cam is a top end cam that isn't very strong on the bottom. I had it in my car at one time. I wouldnt run a 3000 stall if it were given to me for free with this cam. 4k is what you want. I actually had my converter (PTC) loosened up to around a 4200-4300 and I could have even went looser and been fine. It was good for 1.55 60' in a 3500# race weight.
