high volumen master clutch cylinder
Hi,
does anybody know a high volumen master clutch cylinder instead of the stock plastic one.
I ordered the tikt performance one that should be much better because it flows more liquid but the volumen is less than with the stock one. So my clutch releases later then before and before it released very late with my clutch kit.
The left cylinder on the pict is the tiktperformance one that is made very strong but with less capacity and the right one is the stock plastic one.
I search for one that fits or fits with little modifications in my C5.
https://picasaweb.google.com/1175772...75033294676242
Have you doen the drill mod on the line? When I was a 6spd I had problems shifting at high rpms, untill i did it. If you haven't doen this yet you need to before you spend more money.
@ bww3588
Did you read my thread? I still have the Tikt but it has less capacity then the stock one! So i can`t adjust anything because the clutch releases when the pedal is out and not before.
I need one that has more volumen that the clutch releases earlier!
@Brennen's01SS
the RAM one looks same size than the stock one but is it also plastic and has it other connectors?
When it hase the same volumen then the stock one it will clutch at the same point and you can`t change the clutch point only the pedal.
@Brennen's01SS
i bought a tick performance master about 6 moths ago. i will never use anything else. its expensive but WELL worth it.
tick pushes SO much fluid
my clutch releases earlier and the throw of complete action is shorter because of the volume of fluid it pushes
Who did your install with your TICK? If your having problems contact tick and explain it. theres a small chance you may have gotten a bad one. theyll replace it for FREE.
@ bww3588
@Brennen's01SS
@Brennen's01SS
either that or you have something else going on.
As stated earlier volume has nothing to do with the release point for the tick m/c.
Adjust the linkage to get your release point lower. When i first installed mine it released just off the floor which was too low for my liking. So i adjusted the rod a little and now its perfect for me.
If you have questions call tick.
Tony
Tony
