oil pressure mechanical gauge
Old 07-17-2012, 01:49 AM
returf's Avatar
Default oil pressure mechanical gauge
I attached a mechanical gauge to this port is this OK? it's at the opposite end to the oil filter
Old 07-17-2012, 03:12 AM
returf's Avatar
Default Bump
C'mon guys, surely someone knows this. It's just that every other post that asks about putting a mechanical gauge in uses the one above the filter. I'm already using this for the turbo oil feed so I thought I might as well undo this end and screw a gauge in. It reads about 75psi and when the motors reved a little it can go up to 90psi ( seems a little high ) thus I thought i would check that this setup is OK
Old 07-17-2012, 02:49 PM
returf's Avatar
Is there anyone out there that knows the ls1 engine who might be able to help with an answer please?
Old 07-17-2012, 03:02 PM
lazyhomie's Avatar
that is exactly how I have mine setup and works fine.
Old 07-17-2012, 03:51 PM
returf's Avatar
thanks for that lazyhomie, I can rest easyier now
