Difficulty Installing Shorties vs Longtubes??
i was wondering how difficult it is to install a set of bbk shorty headers vs pacesetter longtubes? i know that for a longtube install, some things need to be moved in order to slide them in but is it the same for shorties or can they just slip right in without removing things to clear the area?
Reason im asking is i already have a set of bbk shorties lying around for my 98 z/28 so id prefer to just install these but if the install is just as difficult, maybe id go for longtubes anyways. The hp gains arent really a huge concern to me fwiw
damn, ill prob need at least 4 hours then lol but really, im on a very tight budget and already have the shorties so im gonna just stick wit them. is there a write-up or is it simply unbolt y, slide out old headers, slide in new ones, reassemble?
Moderator
I went "backwards" from long tubes (Jet-Hot) to shorties
(JBA) and the shorties going in was less grief than the longs
coming out. Got it done on my pedestals, Rhino ramps would
have been too low. Car feels the same but runs cleaner in
closed loop. The absence of performance loss may be due
to how sucky the Jet-Hot Y-pipe merge is. Or that when
I'm on it, it's singing at >5000RPM where long tubes don't
really help build out torque all that much.
I like the construction of the JBAs, right down to the baby
velocity spike. But there are some craptastic shorties out
there for cheap, which you're best off not considering. I'm
talking stuff like a 1/2" lip on the ID of the outlet flange,
for some sweet close-in turbulent exhaust gas stack-up.
And the "stainless" is either not, or the kind that rusts just
like mild steel if you leave it in the shed. If it's selling for
under $100, new, there's a good chance it's that garbage.
I would do longtubes. The first time I ever did longtubes was on my LT1! that was a freakin nightmare. I have to admit..it took me a few days to finish, and when i got my ls1 i was so happy because it only took me about 5 hours. Well worth the time and effort though.
I agree, LT's are not much more work just a little more money. I picked up a set of BBK ceramics for $425 total. Install was not to bad. Same amount of work in my opinion. Also did the poly motor mounts. That was the hard part.I definately feel the dif.
