Just installed Jet-Hot long tubes.
Just finished the install. Wasn't bad. Now i have this horrible banging on the floor boards when under heavy acceleration. Is this normal? I had a little less than a 1/2" of clearence between the y-pipe and the floor board. Also the y-pipe hangs a little low. What can i do to fix this little mess or is this what you have deal w/ when you have long tubes. Any in put will be nice. Thanks
Poly motor mounts. You should have done that during the install but hindsite is 20/20
I have this setup with no banging but like you I only had 1/2 clear in lots of places.
I did 1 drivers side motor mount at the same time as headers. I knew the engine torqued alot cause of problems I had getting drive shaft loop/exhaust not to bang.
There is an install writeup on my web site if you decide to bite the bullit. This will fix your problem.
I got my mounts from Thunder ----->>>
