pro's con's of carb set up
Old 08-02-2012, 01:28 AM
devic's Avatar
Default pro's con's of carb set up
what are the pro's and con's of carb set up on ls1, and how much would i be looking at spending
Old 08-02-2012, 02:11 AM
bww3588's Avatar
700 for the intake and brains, and however much for whatever carb. Dealing with carbs on older engines, it's easier to tune as a screwdriver and 1/4 drive socket set will get the job done. However, depending on how good you are at tuning carbs, you could see driveability and power differences.
Unless you don't already have the injection stuff or live half a world away from a decent tuner, I wouldn't put a carb on it.
For a nostalgic look on an older car, maybe, but you can make the best injection system fool old hot rodders into thinking it's a carb.
Old 08-02-2012, 05:07 AM
devic's Avatar
yeah im more so looking for something to many control the spark and fuel idk if there would be a cheaper rout ? for doing this
Old 08-02-2012, 05:11 AM
devic's Avatar
just found this fast XIM stand alone any 1 know bout this even know off subject a bit
Old 08-02-2012, 07:46 AM
bww3588's Avatar
What's wrong with a stock setup?
Old 08-02-2012, 09:59 AM
Moderator
jimmyblue's Avatar
If you're talking about putting it in a stock F-body, I
have yet to see an intake that wouldn't require you
to hack the cowl sheet metal - and one that didn't,
would probably suck for airflow distribution.
Old 08-02-2012, 02:01 PM
slinginrods's Avatar
if the msd box dies ...your fscrewed unless you buy a back up.i have been wrestling this myself for my 83 c10.im more leaning to truck fi for my 5.3.but by the time you buy everything it all costs the same.around a grand.if you gotta get a fi harness its 500+fuel pump and lines 200 ecu tuned 200+ you get the idea.just gotta make your mind up.total power wise they kinda wash.driveability +mileage much better with fi.carb and msd box =easy to tune.
Old 08-02-2012, 05:53 PM
devic's Avatar
not getting spark to all cylinders and cant figure out the problem
