Poly Motor Mounts Install
Old 08-06-2012, 01:13 PM
smahlum_21's Avatar
Default Poly Motor Mounts Install
I finished up putting in my motor mounts the other day. I was having a very hard time trying to get the passenger side in. I had a friend who is a mechanic over and we both tried to get it without any luck. After searching on here for a very long time came across one guys who said take out the pedestal. All i can say is wish I would have saw that post sooner. I didn't fully take out the pedestal but I loosened each bolt as much as possible so I would have a lot of wiggle room. Ended up getting it by myself in no time. Just wanted to throw this out there for all the people who are worried about doing this swap. Don't take the bolts out all the way, just loosen them and you will save yourself a huge headache. Hope this helps out someone
Old 08-06-2012, 04:04 PM
mjs1012's Avatar
i had to redo my passenger side with the header in the car cuz i had the mm the wrong way. loosening the pedestal made it easy.
