Should i swap to a ls6 intake???
I currently have a 99 TA with H/C/I 150shot, it had the weiand lingenfelter aluminum intake on it with a bbk 80mm tb. Would i gain anything to switch to a ls6 intake? Im not trying to start a heat soak debate but when i first drove the car it had ls6 on it and felt alot better, plus this intake stays HOT!!! forever. I went out with a few other cars two weeks ago and after a little racing we went back to a buddys house, after bs'n for awhile (2hrs) i popped the hood and the intake still felt 200*, you could barely touch it, while all the other cars with ls6 intakes where cooled off and didn't burn the hand at all. Just can't decide if its worth switching.
No real gain, but if it makes you feel better then put the LS6 intake back on it.
You have to remember you intake was probably still hot because of the heat transferred from the block and heads into the intake, I bet you heads and block were probably cooler then theirs.
